Discuss Plumber(s) required for 3 house new build in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jbaehr
Looking for competent plumbers to price and work with the design of water/gas/waste plumbing for a terrace of 3 houses in Surrey.
UFH manifolds and pipework will be installed by others - feeds to manifolds part of the job though.
3 kitchens
3 cloakrooms
8 bathrooms
3 utilities
Gas central heating - Valiant or Worcester Greenstar + system fit unvented cylinder.
First fix likely to start January.
PM for further details.
Reply to Plumber(s) required for 3 house new build in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
Morning All, I have 1800’s farm house 3 storeys. Have a single floor side extension. The ground floor single storey extension houses Worcester oil boiler and unvented water tank, in the next door room I have a 30KW Henley Druid stove with back boiler giving 23KW to HW/CH I have also purchased...
I have just moved into a late 1990s new-build house with a small bore (about 1/2" OD pipes) gas fired boiler central heating system. All the normal radiators get hot but two of the three towel heater/radiators don't get hot and the pipes feeding them are cool to the touch even after the boiler...
Hi all, I'm a competent DIYer with an engineering background and am active in Heritage Buildings. I never touch anything I'm not allowed to albeit I've worked on the wet side of my own heating on the central heating circuit before when I had a combi - balancing rads, add a Fernox TF1, washing...
Hi, I'm after some advice on converting my current CH system to Wiser smart system. In particular, looking for advice on whether I can use the Wiser Hub without using Wiser's specialist Underfloor heating controller. Current set-up • System boiler (Vaillant ecoFIT pure 630) with unvented hot...
1K
