Professional Plumber Required Plumber required in Oxford for my imersion heater
Discuss Plumber required in Oxford for my imersion heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Alisondp
Plumber neede to fix my immersion.
Good price please.
Alison
IMGP0321.jpgMy pic xxxxx
Hi Alisondp, Did yer get this job done, I am local and I have a loveslave who could do with some practice on this type of thing
Reply to Plumber required in Oxford for my imersion heater in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have an unvented water heater which for some reason every year causes me issues. At the end of 2023 I noticed that the pressure valve gauge was going up when the water tank was switched on. My local plumber came and re-pressured the expansion vessel as it was flat, afterwards we tested...
I live in an apartment with a cold water tank. The cold water tank feeds the cold water tap in the sink and the bath. Recently, I refurbished my bathroom, and according to the plumber who fitted the new taps, high-pressure taps were fitted. Consequently, the water from taps is of a low volume...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have emptied the water tank in the loft and also closed the main stopcock. still the leak is on - hoping it will eventually stop. I have not idea how the...
Hello. My home's Rheem water heater is dripping from the drain valve. It is strange as it seems to sometimes spit out some water and then stop and then occurs again. I have a little plastic bucket to collect the water, probably about 3 cups of water in a 24 hour period. I was doing some...
The MJ3 Charger on my Mainsboost system has stopped working and I have sourced a replacement, but need a plumber that understands these installations to come and replace that unit and ensure it's commissioned properly. Let me know if you've worked with this system before and can quote on...
