Discuss Please help with water hammer noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
Frais
Hi Everyone
I have a massive water hammer noise coming from "Around" the water meter and main.
I'm leaving on the 1st floor of a flat and every time someone opens any tap the pipes are making a terrible noise.
The taps seems to be ok, no leaks
The toilet filling valve seems to be ok too
I've installed a water hammer arrestor in the kitchen next to the washing machine but did not change anything.
The pipes are rattling also when nobody opens taps
What could be? More thank a bank is a rattle noise
Please find the video below, help!! :bucktooth:
[video=youtube;0ZCuta92XIM]https://www.youtube.com/watch?v=0ZCuta92XIM[/video]
Needs a shock arrestor straight after meter
Unfortunately the space next to the water meter is very tight, I am unable to install one :cry_smile:
Are you sure this will fix the issue?
The plumber said that this noise could be caused from a tap (maybe from the ground floor)
Possible?
Possible?
not if it only happens if when you open your tap
Only happens when I am closing the tap :(
so problem is your end sorry to say
two options
change the tap (may fix the problem but might not)
install a shock arrestor after the water meter
two options
I have isolated all the taps in the flat and tried one by one.
No one leaks and all of them are triggering the same noise when closed (Quickly)
If you slowly close them the noise wan't happen
I wandering if this can be trigged from downstairs.
I don't have enough space but i will try to fit one shock absorber after the meeter
theres your problem if closed fast the noise happens needs an shock arrestor fitting
Unfortunately I've installed one today right after the water meeter. Nothing has changed if not got worst.
However, I had the chance to see the flat downstairs and the noise was even louder. Right after their bathroom sink and inside a wall. I believe the problem starts downstairs and keep the pipe vibrating all the way up.
What If I will install a very small expansion vessel upstair? Would this help a bit?
Thanks in advance
Systems where the pipework is not properly secured at the correct intervals tend to be susceptible to water hammer. (These vibrations are not merely annoying, they can lead to work-hardening and eventually fracture of the pipes.) For example, from memory, horizontal 15mm copper tubes carrying water should be clipped at intervals no greater than 1.2m.
Try adding some saddle clamps to any runs that vibrate.
C.
Hello Frais.
In post 1 you say the pipes rattle when nobody opens a tap but in post 5 you say it only happens when you close a tap. By that do you mean that the other flats using water cause banging/rattling as well as your flat?
Water hammer can be quit difficult to trace.
Have you had the water pressure tested in the building ?
If this noise effects all the flats it is possible that it is the main stop tap slamming shut when you or others, close a tap ( back pressure). This can create a banging noise that sounds throughout the building and if pipe are not secured correctly it will sound worse and be even more difficult to tell where it is coming from.
I would advise you to get a recommended Plumber in to check things over for you.
Reply to Please help with water hammer noise in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
