Discuss Please help what type is this thread is it!???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks. I would to block this out. Not in use. But any end cap which I bought is not much 1-1/2 is spinning the diameter is 1,5mm bigger and the rest is to small.
Do you mean 1 inch and quarter? That’s to smallHave you tried an 11/4 nut
dont know what you mean if the split union nut fits on then thats what you nead a flat faced split union. then the cap or plug will fit into the end of the split unionhttp://www.nero.co.uk/Catalogue/150LB-BSP-Threaded-Fittings/Union-Flat-FaceI try the split union, and was the same then the end cap unfortunately can’t tighten
Do you think this is work? So the thread on the tank is “LB” and this conver to BSP metric?dont know what you mean if the split union nut fits on then thats what you nead a flat faced split union. then the cap or plug will fit into the end of the split unionhttp://www.nero.co.uk/Catalogue/150LB-BSP-Threaded-Fittings/Union-Flat-Face
Tank connector??? Can you please show me what do you mean?What about a tank connector?
do you have anyfittings from where you got the separatorDo you think this is work? So the thread on the tank is “LB” and this conver to BSP metric?
According to my BSP data the dimension over the threads (which you calipered) is 1.66" for 1-1/4"BSP, 1.88" for 1-1/2"BSP. Yours falls just about in the middle! I wasn't aware of a 1-3/8"BSP, but trying metric pipe thread on the web that size is shown. Metric pipe thread is of course based on BSP, though they give it names like G1, R3/4 etc. That might be it, but if it is, I think you'd have trouble finding a 1-3/8"BSP female fitting.View attachment 33343 View attachment 33344 View attachment 33345 View attachment 33346 Hi, I just get this air receiver but I have 2 welded pipe on which is impossible for me to find out what type is it
Thanks all help
Reply to Please help what type is this thread is it!???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
