  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Plastic Piping. tails to taps.. how to tell which brand in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. scrumfled
    scrumfled New Member
    So, my last foray into plumbing was back in the days of copper pipe, gas torches and solder.
    t'other half has bought some shiny new bath taps and they're 'easy to fit' *cough*.
    looking under the bath, theres two 15mm plastic pipes, which have been bodged by the previous owner onto some copper tails from the tap. Before I go down the road of sourcing new flexible tails with push fittings, how do you tell the difference in the pipes (eg is it speedfit or hep20?).
  2. joni os
    joni os Plumber
    Usually can see writing somewhere on pipe, but fittings are interchangeable,except inserts, that are best matched to pipe. Don't use inserts with external rubber seal under a compression fitting.
  3. JCplumb
    JCplumb Plumber
    As above, the insert is the important bit, if the insert is a slightly tight fit then you're golden :)
    Get a few different brands of inserts from a merchants and see which one is the best fit. I know that JG inserts won't go in hep20 and hep20 inserts are too loose in JG. (Or it could be the other way round)
Loading...
Similar Threads - Plastic Piping tails Forum Date
A standard problem. Plastic bath leaking from over head shower. Looking for a Plumber? Post Jobs Here Thursday at 12:29 PM
Plastic pipe separating from compression joint Plumbing Forum Jul 15, 2017
Plastic cold water pipe distance from mains electrical cable Plumbing Forum Jul 12, 2017
How to connect to toilet plastic valve Fittings & Pipes Jul 10, 2017
remove copper pipe from a plastic push-fit Plumbing Forum Jun 27, 2017
Hep2o in plastic conduit Plumbing Forum Jun 6, 2017
How many cisterns have plastic liners? Fittings & Pipes May 7, 2017
