Discuss pipe Leak repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hello Guys,
could someone tell me whats the best way of repairing a leaking pipe from the underfloor heating?
Someone has screwed the pipework with a screw therefore its loosing its pressure and the floor gets totally wet.
thanks for your help
regards
Matchless
Have you got access to the pipe to cut it out and repair? Or tried adding a leak sealer?
Haven't tried with leak sealer don't think it will work. I have space to cut it a section out
Bigger screw?
Piece of rubber with a jubilee clip on top?
(Just kidding of course)
;) haha what a Sunday fix ;) yes is quite a big screw.. I think the whole pipe ends chabging
what brand of underfloor heating is it? Get some pipe and a couple of couplings?
if its 15mm poly cut on the screw hole and repair with a pushfit socket.
should do as a temp fix, I would then advise getting in touch with the uf manufacturer and asking what they use for a permanent fix.
Have u got a link for the pushfit socket
No mate, I said that before you put the photos up.
Why not identify which zone is leaking and isolate so they can have use of the rest of the uf heating whilst you order a repair kit from the manufacturer?
at least it is not concrete fusion weld is the only option for a permanent repair
On my way to do so just a little trouble taking the chipboard up ;) thx for your help
The company name is myson 5 zones I guess it's 18mm
Reply to pipe Leak repair in the Plumbing Jobs | The Job-board area at PlumbersForums.net
