Discuss Pipe clips for soil pipe flush to the wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
I live in a flat so the soil stack is not something I can move.
I have now fitted the branch to soil pipe and also the pan connector to the pan.
The soil pipe is now flush to the wall.
I want to secure it but all the clips expect the soil pipe to be spaced from the wall.
Has anyone seen any clips so i can secure the soil pipe flush to the wall.
Malcolm
Strap band is what you could use , plastic coated punched metal banding comes on a roll just cut it to length to form a bracket
Reply to Pipe clips for soil pipe flush to the wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fitting a new toilet onto this old cast soil pipe that only fits in about 2inches. It's coming through the wall at an angle and can't be changed because of an extension below. The new pan connector keeps dripping on a full flush any ideas on a solution other than silocone which the old one had...
My soil pipe on the downstairs toilet seems to be partially blocked. Now I know it can be rodded but I was thinking of another way. With the toilet removed and exposing the soil pipe I was thinking of making a reducer to fit over the 4 inch pipe down to a garden hose pipe size and then turn the...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
Hi - I'm not an expert but wondered if anyone might be able to assist. I've replaced an old toilet with a new one. I've used the same water inlet pipe, and have just replaced the right angled soil pipe connecter (110 at toilet end to a 97-107 connector end to existing soil pipe). It's secured...
1K
Hi guys, I've had a search and couldn't find anything related. Installing a wall mounted toilet, unfortunately didn't know this when I put the soil pipe in position. The supplied fitting is now approximately 130mm offset from the vertical connection. Any ideas? (amateur obviously!) Wondered...
