1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Dismiss Notice
Couple of important things to note. 1. We use Cookies, deal with it. Every website does. 2. Nobody but a currently-registered Gas Engineer should be touching gas or gas appliances. Don't mess with gas at all.
Discuss PE-X water pipe install... in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. mrebay10
    mrebay10 New Member
    Hi.. I am having my kitchen remodelled and the plumber has replaced the copper piping with PE-X piping to feed the kitchen sink water supply..
    My question is... He has laid the hot and cold pipes next to each other in the floor and concreted straight on top and tiled above, is this the correct way to do it? He says it is fine but I cant help think that the pipes should have been protected somehow.. Does this install meet building regs?
    Any info would be appreciated..
  2. Last Plumber
    Last Plumber Plumber GSR Top Contributor!!
    I know I might be in for if here and this may just be Saturday morning tiredness but what is PE-X pipe ?
  3. Dotty
    Dotty Guest
    It's the new Sharkbite stuff.
    And you're in bad form if you think this is Sunday! What were you drinking?
    SharkBite PEX Pipe: Cross-Linked Polyethylene Tubing
  4. Last Plumber
    Oh my word !
    I can't believe you thought it said Sunday !
    Are you tired too lol
  5. Last Plumber
  6. Dotty
    Dotty Guest
    Never tired. Constantly awake, me.
    Poised and waiting....
  7. Last Plumber
    Like a coiled spring ?
    Lol
  8. Dotty
    Dotty Guest
    Lager? White wine chaser? Girl!
    • Like Like x 2
  9. Geyser
    Geyser Plumber GSR
    No it doesnt.
    Should be put in a conduit pipe so its protected and can be removed if needed.
    • Like Like x 1
  10. Last Plumber
    Nope, Guinness with Rum chaser !
    • Like Like x 1
  11. mrebay10
    mrebay10 New Member
    Thank you for replying with an answer Geyser...
    So the problem I have now is.. Do I need to get him to take up the tiles and redo with coduit?
  12. ShaunCorbs
    ShaunCorbs Trusted Plumber GSR Top Contributor!!
    two options
    lift up if you have enough tiles spare
    or leave it, will be fine but if you need to replace it in the future you will need to lift the tiles
Loading...
