  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Pathetic water pressure from shower in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. animal47
    animal47 New Member
    Can I please get some advice on how to best cure my shower problems as cheaply as I can.
    We never used to have any trouble with our old central heating system consisting of a water tank in the loft as well as a hot water tank in the airing cupboard and back boiler. After a house fire it was all ripped out and a new greenstar 30si fed straight from the mains water was fitted. We only have a 3 bed semi with one bathroom and a total of 7 radiators and we have triton rapide 4+ electric shower.
    Our water pressure is very poor and barely powers the shower and if anyone so much as has a tap dripping downstairs in the kitchen or the washing machine is on the the shower cuts straight out and goes stone cold, in fact at times it will refuse to work properly even with nothing else on in the house.
    What can I do to remedy this, can I fit a pump on the line supplying the shower.
    Any advice much appreciated as it is so annoying.
  2. Riley
    Riley Plumber GSR
    Implies blockage or something not fully open?
    • Like Like x 1
  3. scott_d
    scott_d Plumber GSR
    Check your internal and external stop taps
  4. animal47
    animal47 New Member
    The internal stop tap in the kitchen cupboard is definitely fully open. As for the external one, do you mean the one out the front of the house under the pavement.
  5. Riley
    Riley Plumber GSR
    Yep
  6. animal47
    animal47 New Member
    Both taps fully open. I did actually have a bloke from the water board out a couple of years ago to complain and when he tested it, it was apparently just above the bare minimum that they agree to supply so he wouldn't turn up the pressure although he did say he would check a few more houses in the street to see if he could find one under pressure so that he had an excuse to turn it up but I don't think it ever was increased.
  7. Riley
    Riley Plumber GSR
    That might be your starting point again then mate. What're other taps like??
  8. animal47
    animal47 New Member
    To be honest everything is pretty pathetic.
    Worse case scenario and that I get no joy from the water board, is there a way of installing a pump on the shower inlet as I am used to the tap pressure being rubbish but the shower is just a constant irritant
  9. scott_d
    scott_d Plumber GSR
    What type of pipe comes on from the street? Blue or black plastic or lead
  10. Subby
    Subby Plumber GSR
    Salamander homeboost is needed
  11. animal47
    animal47 New Member
    It is a black plastic pipe coming into the house
  12. animal47
    animal47 New Member
    Looks great and would no doubt be easy to fit onto the combi main inlet BUT is there no cheaper alternative lol as that looks quite an outlay for just after Xmas.
  13. johnf
    johnf Active Member
    Your best bet is to get someone round to do some tests on water pressure and flow. To be fair this should have been done before the new boiler was installed. Without knowing what you have at present and what you need it is hard to advise what is best for the situation. Stuart Turner and Salamander do a pump that you can add to the mains which will increase the flow to a maximum of 12lpm but this may not be the cause.
  14. animal47
    animal47 New Member
    Who should I get to check pressure and flow, is that a plumber or water board job.
  15. johnf
    johnf Active Member
    It should be done by a Plumber/heating engineer. Explain to them what you want doing before they come out as you want someone to do it properly.
Loading...
Similar Threads - Pathetic water pressure Forum Date
Hoses and connectors for water softener Fittings & Pipes Today at 10:36 PM
Grey Water pipe size? Fittings & Pipes Today at 9:19 AM
Water filter tap from Mains or from kitchen Tap supply? Plumbing Forum Thursday at 7:48 PM
Instant hot water tap valve Plumbing Forum Thursday at 4:46 PM
I think my hot water cylinder hasn’t been plumbed in properly Plumbing Forum Thursday at 1:42 PM
Problem Hot Water not getting hot Central Heating Forum Tuesday at 7:47 PM
Baxi Instant 80HE not detecting water flow Plumbing Forum Jul 17, 2017
