davenport.neil
Can anyone tell me, is residue from passive flux such as "la-co" corrosive after the soldering process is complete?
Thanks.
Thanks.
Discuss Passive flux in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Yes la-co is corrosive, just as all fluxes are. However, it is gas council approved and is suitable for use in the uk for water as well.
It should be used with caution - only flux the male ends, not the fittings, and removed with a damp cloth after soldering. Heating systems should be thoroughly flushed, both hot and cold to get rid of any internal residues.
However, if these conditions were not satisfied, flux on the outside of joints leaves a green unsighlty residue.
On the inside of systems, it an be argued scientifically through sampling and scientific reason, that an increase in the ph of the system water acts as an electrolyte and may lead to electro-chemical corrosion in the prescence of disimilar metals usually found in heating systems. However such occurances would not be down to the flux, but down to occupational quality.
... gas doesn't contain oxygen [so] you shouldn't get oxidisation?
That's exactly what I've always thought but I've never heard anyone else say it before, let alone say it with authority!
Oxidation requires free oxygen, and water doesn't spontaneously decompose much. If it did we'd be living in a hydrogen economy (and quite thirsty).contains some water residue tho and thats made of?
yes its worst than passive smoking your arms/legs/fingers/lungs/head/todger/nose etc might rot away and fall offCan anyone tell me, is residue from passive flux such as "la-co" corrosive after the soldering process is complete?
Thanks.
Hmm is it worse than say powerflux? I thought la-co was non-toxic and therefore not as bad for you in terms of fumes and irritation etc.
Bind? Is that flux lock?
Reply to Passive flux in the Plumbing Jobs | The Job-board area at PlumbersForums.net
