Discuss overheat stat on solar thermal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
what would be the solution if the cylinder has only one overheat stat but the job needs east west panels
Reply to overheat stat on solar thermal in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
Fitted unvented hotwater cylinder building control looking forms signed it off job was in england i am qualified northern ireland send out a form to fill in what do u need to sign off in england as building control said they dont give out forms like they do in northern ireland
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
