Discuss Overflow from loft in attic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Noel Sherlock
The overflow from loft in the attic is dripping outside on occasions and feel that the problem is in the header tank. Unfortunately being retired unable to get into the attic as body is not as flexible as it used to be and have no wish to fall. Could you give me some idea of cost in someone fixing this which for an experienced man should be one of the easier jobs.
Thank you
Hi Noel, firstly could you register as a member then repost in the link below adding your rough location, many thanks.
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
As above.
Please register with us and start a new thread to receive an answer to your question.
Reply to Overflow from loft in attic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
