Discuss Outside tap needed - Falkirk area (Larbert) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eisenhorn
Hiya, I'm needing a plumber to fit an outside tap in the back garden, directly from the kitchen. I'm wanting to use it for a pressure washer, so need a kit that's not just an self-cutting kit. It's a new build house, so should be straight forward enough to get in, but under sink space is limited by the back board.
Anyone who has a spare hour or so and in the area, please contact me and we can hopefully arrange.
Cheers in advance,
Eisenhorn
The top plumbers on here wouldn't dream of using them self cutting kits lol, they are the pits lol
hehe, yeah, even as I was reading up on them I could see they were the bottom of the pile for their usefulness and worth.
Hey I stay in Falkirk but I will properly be fitting the tap we don't use self cutters
Steven
Thank you for posting this opportunity for our members.
If this interests you, please pm the op direct.
Reply to Outside tap needed - Falkirk area (Larbert) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had an outside tap fitted by a professional plumber last autumn. During the recent cold weather the feed pipe under the kitchen sink froze and the compression joint where the pipe enters an isolation valve now leaks. The outside tap was covered for the winter by an insulating blanket. I...
Hi all I'm having an issue with my outside tap not working, the tiniest of dribbles comes put each time I try it. Ive changed the tap to no avail so thinking I should change the stopcock tap thing under the sink? Please see attached photos. Many thanks for and advice. Cheers Gary
Hello guys, a couple of months back I installed a new shower and sink into a part of the house that hadn't previously been plumbed in. This forced me to run some pipes outside the walls, so I put in stopcocks at the point where the new pipework joins the old Just In Case. I used copper pipe and...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to create a cloakroom toilet in our utility room, theres already hot and cold feed so thats one job made slightly easier, thankfully. The problem I'm...
Hey Team Looking to fit an outside tap, gone to see what I'm working with under the sink and as you can see from the imagery I've got 2 Hose union outlets already sat waiting for me. https://i.*********/uyUCb6s.jpeg - Image Is it as easy as connecting those to the outside tap pipe, via hose...
Deleted member 120897
