- Messages
- 20
I am very sorry John for the confusion.I'm getting increasingly confused with this Lee.
1. I did intend to run the 22mm vent pipe to the tank and combine it with cw outlet using the tee as per your system.
2.yes
3.i thought the new 22mm supply would run to the left top side of the H which is the current vent pipe as in the attached. The top right is the curr 15mm cw supply that I thought needed to be capped.
Apologies again I just didn't want to make a mistake.
Just answer, if you don't mind, these queries one by one.
1. Do you (or have you) propose(d) to run a 22 MM vent to the new header tank?.
2. Do you intend to run a 22MM CW supply to this from the new header tank.
3. Where do you propose to connect in this CW supply to the 22MM vent.
Thank you for your patience John that is exactly what I thought I had to do but didn't explain it very well.Here is a very simple schematic of my proposal, can you just post something similar with yours.
Thank you for your patience John, thats exactly what I thought I need to do but didn't explain it very well.Here is a very simple schematic of my proposal, can you just post something similar with yours.
I am combining the cw feed as per your drawing using 22mm and capping off the 15mm supply.
Thanks again
Lee
