Discuss one pipe system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
can anyone tell me if you can put a combi condensing on a one pipe system using a baxi boiler cheers
you can but it wont work very well,stick a performa 30 on it for example and the water will pass its self backwards
cheers gas man ive got a one pipe system and my mate who has just passed his gas safe has just installed one and has told me i could do it on mine but i was suspicious so now i know thanks
We did one last summer on an existing in chesterfield. On the nearest rad stick a iso on it so that rad dont suck all the heat from the system before chucking back to the boiler and leave of some trv's.
It works but not to its best (main 30he).
Your mate needs more training. One pipe systems do not appear in modern heating systems. They are unreliable and bad practice. What was he thinking of.
one pipe system are old fashioned and not good for domestic properties, ok for schools n such
why wouldnt a combi not work well?
pressurised system,rapid flow and warm up i will leave you work out the rest
err, help me out gas man, is it because the hot water will struggle to circulate through the rad with the pressure and rapid flow?
basicly yes the combi will throw mass amounts of heat that a one pipe system can't cope with because it offers to little resistance,the water will want to fly around the system and by pass the rads one pipes work best on a slow plodder of a boiler
you could use swept tees? but yes they are not really suited to domestics.
ive worked on loads in schools and even fitted one in 1997 in liverpool, a new primary school
they are oversized peipes as they aare both flow and return and use the pipe as part of the heat emmitter
Reply to one pipe system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
