Old leak from basin waste pipe needs reseal
Discussion in 'Bathrooms, Showers and Wetrooms' started by PB108, Dec 27, 2016.
  1. PB108
    PB108 New Member
    Looks like a previous sealing job has failed (although not currently damp as the house un-occupied for 4 months) by using some unknown sealant and resulted in previous evidence of rotted carpet below this joint & infestation of some form of critters in area (a white powder has been used so maybe ants?).
    Any recommendations chaps what the best cure, sealant, for this please?
  2. rpm
    rpm Plumbers Arms member
    Welcome to the forum.
    looks like a simple "Push Fit" connection which relies on rubber washers to seal. Buy another T piece however the pipe where the sealant is looks undersized unless it is just in the photo.
  3. turnpin
    turnpin Plumbers Arms member
    Welcome PB108....looks like a bit of a bodge sealed in with silicon best thing cut it out and remake the whole joint I.e the Tee piece see if you can see a name on the fitting looks like push fit so may be easier than it looks....take that photo to your local merchants best of luck regards Turnpin:welcome:
  4. PB108
    PB108 New Member
    Yes it looks like it cold be undersized as said, but also not much room to get out original T piece either as per new photo. DSCN6137.jpg .
    Maybe be easier to re-seal?
  5. townfanjon
    townfanjon Plumbers Arms member
    By the looks of the pic you need a 40/32 mm pushfit reducer and a new 40mm tee
  6. PB108
    PB108 New Member
    Thanks the T piece has stamped on it:
    BS 52 54 PP 2-50mm WP 560.50
    Nothing for the pipe going into it.
    I was thinking some plumbing mait layer for now
  7. Radioman
    Radioman New Member
    Bodge it and scarper! Do it right do it once. Replace the T piece, fit reducer, good for years.
  8. joni os
    joni os Plumbers Arms member
    Slip coupler needed on horizontal run due to lack of movement. Remake connection with new Tee.
  9. PB108
    PB108 New Member
    All good suggestions, however there is very little room for manoeuvring the T piece out as top joining pipe goes straight up to loft & out to breather on roof and bottom piece dives down below solid floor :uhoh2: the side piece goes to the adjoining room's basin.
  10. townfanjon
    Are you sure ? , we have had a right pro on this one lol
  11. Radioman
    Radioman New Member
  12. PB108
    PB108 New Member
    No it's a bungalow; only soil pipe below & air breather above; side pipe is the basin outflow.
  13. Radioman
    Radioman New Member
    Then do as post #11
  14. PB108
    PB108 New Member
    Am currently trying ensure the outflow is not blocked by pouring soda crystals in hot water down, my theory is that a blockage built up in past & overflown the joint, as it shouldn't be leaking at all as inclined at decent angle enough.
    The vertical pipe diameter is 53mm where the horizontal in flow is 35mm dia.
  15. turnpin
    Remove the pipe from the trap on the other side of the wall that will allow you to remove the pipe entering the middle of the tee then see if the vent pipe will twist out of the top of the tee if not cut a few inches above the tee ...renew as required adding a slip coupling to the vent pipe then just work back to the trap ......get all your fittings and pipes before attempting this straight forward repair......alternatively get a plumber in....regards Turnpin:)
Share This Page
