Discuss oil condensing heat only boiler not firing up!!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
How can I do that?
100 posts, which you have, and a private message to one of the mods.
Hi Simon can you explain how I can get into the plumber arms
Just because there is oil there, it doesn't mean there's enough to run it. I would bleed it for a bit to make sure of the fuel supply. It's easy and you don't have to pull anything to bits. Then pump off to make sure that the dog coupling is intact and that the motor is running at full speed. Then lid off the pump to check pump filter. Then change pump.
^^^ This.
Reply to oil condensing heat only boiler not firing up!!!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
