Discuss oil Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coley
What is the procedure for setting the oil pressure on a oil boiler burner. Which pressure gauge kit to purchase.
Coley
Better getting someone to set it up for you as if you change one thing you will have to change another. Should only cost around £80 or so
Testo Oil Pressure Gauge Set, priced at £69+vat on OFTEC website.
Basically, plug it in, turn on burner and adjust oil pressure accordingly, then do air. Then smoke test, then FGA, then smoke again. Easy, peasy when you know how and had a few goes but nerve racking on first few times. Presumably you're OFTEC qualified?
Hi Coley. When active in this work. I approached oil companies on behalf of client and give the oil order to the one that would commission burner etc. Saved a lot of time, expense and shed a bit of responsibility. Good Luck
I already found the 2 pressure test kits on oftec direct. however whats the difference between the two apart from price.
Coley
Reply to oil Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
