Discuss Oil Boiler Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Carlic
Hello all
A 'plumber' had attached our oil burner after a service to the boiler housing using fire cement... is this acceptable or is this a disaster. If the latter what's the best way to rectify?
im just thinking back and something is telling me that shouldn't have been done... any advice would be a huge help!
thanks
Hello all
thanks
why did you get a 'plumber' to service your oil boiler ?
Most service engineers are plumbers/ heating engineers .
To the op. Can you post a picture of the burner. .?
Reply to Oil Boiler Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
Hello The heating side of my Ariston Combi A23 has stopped working since a new 3 way valve has been installed. It's been a hugely reliable boiler up until now with regular servicing. When the heating is turned on the boiler ignites and looks to start up but then a few seconds in, knocking sounds...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
