Discuss Oil boiler people - which jointing compound do you use? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WHPES
Stag
Heldite
Foliac Red
Rocol Oilseal
Other?
The only thing I have against Heldite is that it's bad to get off your fingers and doesn't wash out of overalls like Stag does.
Reply to Oil boiler people - which jointing compound do you use? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I have a condensate pipe that appears to be leaking at the joint. How do I fix the leak? Would something like plumbers putty around the joint work or does it need to be some other compound? Can I simply pull the pipe and joint out and then put the compound round it Thanks
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes...
Ive fitted a new bottom entry fill valve to our en-suite toilet but i cant stop the dribble/leak from the inlet connection. Ive added a fair bit of ptfe but its still leaking, tightened it to its maximum etc and still im getting a dribble. Do you think i need more ptfe, add some joint compound...
4K
Hi, can anyone tell me which pipes are flow and return please. I removed old leaking 2008 C26 firebird oil boiler in June . We have now completed damp proofing works & I need to extend these 4 pipes to go through the wall and into a new boiler room. This area will then be stud wall and...
Recently I needed to re-route very old and dodgy oil pipe from tank to boiler. I dug trench and laid a duct and the engineer used green plastic (Pipelife Qual-Oil?) oil line to do the job. Had cause to have boiler manufacturer out to look at something yesterday and he remarked that this Qual oil...
2K
