Discuss Oil and Solid Fuel Forum Stickies. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Reply to Oil and Solid Fuel Forum Stickies. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated heat source and a oil boiler. The problem the hit water cylinder doesn't have a stat thus why the hot water is roasting hot but there is a pipe stat on...
A bit of an unusual topic, as these are very rare in the UK. I went back to Poland to commission, test and tune the 20kW solid fuel boiler and the domestic heat exchanger for the hot water tank (300litres). Old heating system with steel 2-inch pipes and cast iron segmented rads We were warned...
Hi We have a vented oil-fired heating system with a coal fire back boiler, this is going to be changed to a sealed pressurized system tomorrow and I believe, they are decommissioning the back boiler. I have only discovered today there is no access to the water jacket, so will it be good enough...
Hi Have a 4 port solid fuel back boiler, is the any disadvantages of capping two of the ports off, (eg top left bottom right) then using it as a two port for HW and heating with a injector Tee, only reason iam asking as would cut down on pipe work coming from boiler and just out of interest...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts needed to operate it are now new. The symptoms indicated a broken/seized burner motor or oil pump. I wrongly assumed the motor so I ordered a new one only...
