Discuss Not soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
Cannot understand why the solder is going into balls and dropping off the pipe. Must be making basic errors but cannot understand what. As the soldering yesterday was fine.
Any ideas
Pipes cleaned with wire wool? Properly fluxed up? Water in the pipework?
I'd say most likely water in pipe
I would say pipe not clean as it's melting and dripping of and not sucking into joint
Overheating can cause this. As other's have said water in the pipe can also cause the opposite issue of not reaching soldering temperature and the solder will bead or run off.
Pipe not cleaned or fluxed properly. Overheating burns all the flux off.
Thanks everyone for your replies. It is copper pipe and it was cleaned and no water in the pipe, so i guess I have not fluxed enough
Try not to heat the joint too much and keep adding flux on the end of the solder wire.
When the solder wire just begins to start melting, (touching copper, but not under the flame), you are normally only 2 or 3 seconds from the correct temperature for soldering.
If the clean pipe and fitting inside and outside hasn't been "tinned" (coated in solder) then it will not solder properly when the flame tarnishes it. That is why you need to keep the surfaces fluxed. Note that capillary action also works well with flux, so don't be afraid to add flux as you solder.
Reply to Not soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
