Discuss NO I AM NOT AN UNDERFLOOR HEATING EXPERT! in the Underfloor Heating Forum area at UKPlumbersForums.co.uk.
  1. Dilalio
    Dilalio Member
    I recently had to use TI to locate my son's corn snake which had escaped in the car on the way back from the reptile shop he works at :)
    • Like Like x 1
  2. Dilalio
    Dilalio Member
    Funnily enough, I had to use it in reverse as the the snake is cold-blooded :D
  3. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    So, not had chance to buy a TI as yet as so busy. But popped back to this job yesterday. To take a more in depth look. So I have some pictures and I known it is a mess but just after a bit of advice as UFH is NOT MY THING. If you think it is better for me to pass onto an UFH Engineer I will do so. Quick update all rads eventually come on with the UFH 2 port open. But not when the hot water 2 port is open.
  4. Harvest Fields
    Surprised no one has commented. Still pulling my blooming hair out.:p:p
  5. ShaunCorbs
    They haven't used an old feed from a rad to heat the underfloor/ supply the manifold have they?
  6. Harvest Fields
    But that wouldnt explain why it has only just starting to do it. The owners is adamant that they used the UFH more then the heating and it defo didn't do it before?
  7. ShaunCorbs
    Heating two port been replaced?
  8. Harvest Fields
    Yes mate.
  9. ShaunCorbs
    so the heating doesnt come on with the hot water at all?
  10. Harvest Fields
    No mate the hot water 2 port is perm open as is a thermal store. Rad cold when water only is on
  11. ShaunCorbs
    why a thermal store?
  12. Harvest Fields
    No idea but presumed it was as the hot water two port was perm open with no timer.
  13. Harvest Fields
    To be honest I thought it was a normal unvented but when I said to a work mate the 2 port was open all the time when there was 240v present he was the one that said thermal store so I went with it.
  14. ShaunCorbs
    was it going to the coil?
  15. Harvest Fields
    Yes
    Yes mate
Loading...
Similar Threads - UNDERFLOOR HEATING EXPERT Forum Date
Combi boiler flow temperature with underfloor heating Underfloor Heating Forum Apr 22, 2018
Advice for heating system to install Central Heating Forum Jul 12, 2018
