- Messages
- 29
Does this mean that say during the summer we dont have the heating on, we wont have hot water? if i switch the hw on via the nest will that heat the water only without heating the house, if that makes sense.
Discuss New WB boiler - with tepid 'hot' water! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Apparently, if i keep the ch dial at 3 this should produce water at about 50dc which would be too hot to bathe/shower in...the temp produced by keeping at setting 3 is definately not too hot.
Is there a 3-port (or two-port) valves, external to the boiler?Evening folks,
So, I am here for some independent advice, if possible. I have just had a Worcester Bosch 30cdi Classic System Boiler installed along with a ?mag filter? and some new radiators. The issue is that the hot water isn't very hot at all. I have turned the thermostat on the hot water cylinder up to 70 degrees; with no noticeable change. I was told at the point of install that the hot water dial on the boiler itself is only for if the boiler is a 'combi' and on my boiler it is essentially useless.
Can anyone make any suggestions as to why the hot water isn't very hot? I have it on for a good while giving it plenty time to heat but it doesn't make any change.
Any suggestions are welcome. Many thanks,
MR
Reply to New WB boiler - with tepid 'hot' water! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
