Discuss New house move, two appliances one water source in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
curtcosmic
I have one water supply and i want to run two appliances,
a dish washer and a washing machine.
The parts i have been looking at using are.
Compression appliance tee from screw fix and a twin waste adapter from amazon,
Would i need anything else ?
Any advice on getting the ball rolling would be great !,
i will post before and after pictures also.
Looking forward to your replies
Curt
Why not just get someone in to do it ? some of these so called simple jobs can turn into a nightmare,, the cold side is simple enough, but you may have a problem with the waste .
you will probably find that a compression appliance tee won't allow the further appliance to reach, same for the waste
Ideally it needs to be done properly with an extend run of the copper and waste
If I`m not mistaken you already have a T junction on that pipe, where does that pipe go to?
The white waste pipe goes out to the drain outside, and the copper pipe comes from the cold supply, and gives to the washer and sink
The appliances are next to each other, so i would not need to extend anything fortunately, i just need to give the water source two outputs
Thanks for all the help, its done now everything is working great :)
Reply to New house move, two appliances one water source in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
Hi all - hoping to get some advice here on a plumbing issue in our house. When we are showering / filling the bath and another appliance draws water (toilet cistern filling after flushing, tap being turned on or washing machine filling etc), the water pressure / flow to the other appliance...
Azonic
A
We have a utility room with a washing machine but no sink. Wife wants sink. There is room to fit one and the waste will connect to wahing machine waste but the problem is in the water supply. Currently there is only hot and cold washing machine hose fitting isolators attached to very short...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern pipe/u-bend/fittings to kitchen sink, rinse sink etc as preventative maintenance! Nothing complex or specialist, that's for you expert guys! But in...
My dish washer and washing machine are installed next to one another per the attached picture. After using the washing machine waste water per the attached picture fills the bottom of the dishwasher. In the attached picture this the waste water after 2 washing machine loads. Attached is a...
1K
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
