Discuss New hot water pipes have Smaller Diameter, does this change anything? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
My plumber has changed the hot water pipes in the bathroom/kitchen
and they are now slimmer – diameter has been reduced from 30mm
pipes to 22mm and 15mm pipes too. Will there be any difference
to the water pressure because of this or any other noticeable change?
not if you are on a combi boiler. if hot water is gravity then flow rate will be affected and not pressure. if you have the diameters correct then 22 will be adequate for most domestic premises
- Status
Reply to New hot water pipes have Smaller Diameter, does this change anything? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, basic question, any insight much appreciated.
Looking to have an outdoor tap in my front porch fed from 15mm pex coming up from suspended floor. Pic 1 is inside porch, pex temporarily clipped to give an idea of pipe placement (ignore shoddy blockwork of booted cowboy builder!), Pic 2 is...
Morning to any Australians lurking around! Register its free, then message me, I'll sort your account out for you. We will need a moderator from each main country too.
I'll post this in the Australian forum now.
