Discuss new central heating pipes and radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hagan10
Hi there
Would like a price for full central heating pipes replaced along with total of 13 radiators and 2 towel radiators.
Had a combi boiler fitted 1 year ago.
I am based in Ryton, Newcastle upon Tyne
Hi hagan10, we don't discuss prices on here due to regional differences in costings, if you post in the I'm looking for part of the forum someone close by could help you out.
Good luck.
Here you go.
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
He already did you numpty.....
Thanks for the opportunity.
If this job interests you please PM the op direct.
Reply to new central heating pipes and radiators in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
Our house was built in 2007 and we are the second family to live here - moving in in 2017. The central heating has been working fine - although the gas boiler is perhaps nearing the end of its life. But the boiler is not our current issue. Last winter two of the radiators did not heat up and...
1K
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the radiator and the water was black/brown. I took the radiator off and flushed it out with a hose pipe out the garden but it's got me thinking and I...
