Discuss New Central heating but problems, Please help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have skim read this thread with there being 70+ posts so forgive me if I repeat anything that has been said.
Your Boiler will give 13 litres per min @ a 40 deg rise +/- 15%.
If you are testing the mains cold water flow rate at a tap, that does not mean the flow rate at the entry point on the Boiler will be the same. The standing pressure would be similar of course, (depending on how high the appliance is) but not the flow rate.
You will lose flow rate due to frictional resistances in the pipe work from the mains entry point in your property to the appliance. This may only be minimal.
I would ask the installer to test the flow rate beneath the Boiler and see what it is there. Then you can address whether the issue is a lack of flow or a problem with the Boiler itself.
There is a flow regulator inside these (erp version) and there is a strainer in the inlet.
If you want to run two taps you will be sharing the hot water from the boiler between them. There is nothing you can do about that with this Boiler.
Did you seek advice and discuss your requirements with Heating Engineers prior to deciding on a combi?
Unfortunately it does sound as though you have the wrong system for you. Even if the Boiler was delivering 13 lpm at 40 deg rise, it would still be unsuitable for you by the sound of it.
I have always said if you have the required supply and room for an unvented cylinder, always install a cylinder. Combis are best for small properties with only one bathroom unless you can afford to go big kW and even then a cylinder will perform better in most circumstances. unfortunately OP doesn't currently have sufficient incoming mains flow and pressure to make an unvented cylinder work properly.
A 300 litre cylinder and an accumulator same size might do the job if there is enough pressure to charge the accumulator acceptably.
But I am sure that Dale Sanders is on about pitting the accumulator onto there existing combi.
Yes so what I have been advised by the engineer who installed the system is if I want to increase flow I would need to add an accumulator, he is suggesting that i get a 240l mainsboost vessel with 22mm upstream system. I am being quoted £760.
Your Boiler will only give you 13 lpm at a 40 degree rise plus or minus 15%.
It does not matter what you connect it to, it will only give that.
If you think it is worth the money for the extra 3 lpm, that’s your choice of course.
A 36 KW Combi, 240 litre vessel and £5670, to give you 13 lpm seems absurd.
Is this a DIY gone wrong ?
Sorry Dale but if it isn’t, you need to be asking for this to be put right without any further expense to yourself !
Surely the installer took measurements of pressure and flow amongst other things before doing the job ?
I know. The problem is that nothing OP does to his system will make that combi do what he wants. A good sized cylinder with a good supply (better than they have at the moment unfortunately) is surely the best way to achieve performance on two hot outlets simultaneously.
To fit an accumulator with its cost for the gain of 3 or 4 ltr./m of hot water performance is not worth it in my mind but it's not my money.
The only practical way I can see involves a cylinder.
Would that mean removing the the combi? I have already emailed the installer stating I am not happy. Just waiting a reply
No you can fit a unvented cylinder on your combi but incoming flow and pressure is key
Ok. I have not even been given that option.
I will do whatever it takes but nobody is telling me a guarteed fix.
What do you mean about flow and pressure is key.
For any system to work correctly over two outlets you need about 3 bar and 20lpm on your cold main
I feel like I'm going around in circles don't get me wrong I really appreciate all your help but I don't have 20lpm I have 14lpm mains in and I have 3 bar. What can i do to resolve my issue with lease hassle and expense. I cannot remove the combi as I'd prob have to take the engineer to court for that the happen. Cheers
If you only have 14lpm that's no good for an unvented or a combi esp if you want two outlets
If you want to increase your flow, note not really worth doing that on a combi as your stuck with x amount as there limited
Stuart Turner
But that system will only last around 10 minutes at full flow eg 15lpm etc
One sure way to remedy this problem...Alter the Combi to act as a system boiler and install open vented S plan system using cylinder and CWST.
The head of water from your CWST and Hot Water Cylinder will be equal and if the flow rates still are'nt good enough you could even install a shower pump.
As someone stated earlier in this post, Combi's are ok for small one bathroom properties but that is basically it.
I wonder how many people throughout the years have ripped out open vented systems only to regret it once they realise how much more restrictive pressurised systems can be.
Pretty much everyone who's had it done I suspect...
So had another local plumber out and without turning on any taps he identified the issue straight away. There is a double check valve on the mains going into the boiler. He says that can restrict flow by a lot. Thoughts?
Yep there's a couple of lpm why was it installed, doesn't need to be
Also needs a shock arrestor fitting at the boiler on the cold mains
Reply to New Central heating but problems, Please help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
