Discuss New Boiler & Powerflush Needed, RG10 (Reading/Wokingham) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stu0x
Hi there
Our C/H and hot water has completely stopped working. British Gas came round last night and told me in no uncertain terms that the system is completely blocked and needs flushing. And to make matters worse, apparently the heat exchanger (which would need to be replaced) is no longer made, so a new boiler is needed.
So I'm after a second opinion, and assuming the above is correct, a quote for a new boiler installation and a powerflush. Ideally ASAP, given the weather.
Any help gratefully received.
Stu
Hi Stu
Thank you for posting your possible works requirement on the forums
Any members who maybe able to assist the op,please pm him direct
Reply to New Boiler & Powerflush Needed, RG10 (Reading/Wokingham) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It required a drain and refill of the system, and as he left, he advised my I would need to bleed all the radiators, at some point, given a few days, when...
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be making things worse. I really need another expert's opinion, to put my mind at rest, or help me make the decision to stop using his services. I...
3K
We had a Gloworm Energy 7 30r Boiler fitted in Jan 22 to replace a British Gas Boiler (which was a Glowworm Rebranded ) when the heat exchanger split after 10 years. The old boiler had a pressure gauge on the fascia but this new model is not fitted with one. After it was all fitted I queried...
2K
Recently over the past 2 months, the boiler or area by the water tank has started making a loud groaning noise whenever hot water has been running for much over a minute (sometimes less). Since the weather has gotten cooler, the radiators seem to come on (unless turned off at the TRV) whenever a...
2K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical, carpentry it's been never ending. The house was built by Barratt Homes in the year 2000, it is a 3 bedroom house called a Palmerston, the CH/HW system is a Y...
5K
