Discuss need to see this new pipe straightener / new tool in the Plumbing Jobs | The Job-board area at PlumbersForums.net
They have a rodent problem? You are happy to do an install when there is a chance of a rodent infestation?
I understand requests, but they do not know better than us, is the plastic no good for use?
well they have caught a few in the loft spaces in the past year or two and the loft has traps so we best take care :). The customer does not want any plastic pipe and i would not use it in this instance anyway because fittings are to big for pipe routes. half the floor has joists only 125 high so we cant run in them, so alot of surface running which will be skirting boxed which is how alot of its run already. The house layout is different heights and shapes and nothing is straight forward.
i know exactly how good plastic can be in suitable situations, i have first fixed hundreds and hundreds of new build with plastic, from standard 3 beds to huge multi million pound house's and plastic was the only option with the joist system and wall types but its not suitable for alot of my current work either due to contract spec or installation needs.
Im yet to meet a single customer that is happy with having push fit. They always want copper and i mainly use 10mm copper for radiators. Never had a single problem with it
Reply to need to see this new pipe straightener / new tool in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with the experience I have picked up over a lifetime. I can make copper pipe runs isolaters taps sink shower etc but me and the missus have bought a small...
I have a question that I’m hoping those of you who are experienced central heating engineers may be abler to throw some light on. But first I need to tell you about my system, and the problem I’ve been having. Just over 7years ago I had a new CH system installed in my small semi. I say new – in...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Hi, I have a leak on the live side of one of my rads, in the GF loo. Its a condensing combi system, the house is only 5 years old, so fairly new. The leak is at the bottom compression fitting on the lockshield rad valve. The rad is a chromed steel towel rail, and the valve is brass/copper, the...
