Discuss Need help finding a fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
thedog123123
I just moved into a flat with a 1.5 kitchen sink (1 1/2 pipes). The waste pipes are setup similar to this picture here:
Sadly, the piece that is circled was cut to short by over a 1/2 inch so it doesn't fit well into the bottom part of the piece. I went to try find a connector like that but I couldn't find one. I did find something similar but it has a male attachment at the top not a female which I need to connect to the sink basket.
w2w.diy.com/departments/floplast-waste-trap-height-adjustor/152689_BQ.prd (change the 2 to a w to view link in www)
I am a novice with plumbing and any help would be appreciated
take that picture to a merchant buy the whole thing keep the bit you need and bin the rest, you cant get the adjustable pipe separately
as above you'll need to buy a whole new trap or get a trap extension piece if it'll fit although i prefer less joints where possible
Trap extension piece for a kitchen sink (1 1/2") will do no problem
Reply to Need help finding a fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
