Discuss Multifit connections? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. alexmurchison
    alexmurchison Member
    Hi all. So I've been requested to replace a cracked. As in in a country park Hall. If it wasn't hard enough locating an under counter bowl of the correct size. (Coming from Dubai) of all places? All the wastes and tbh most the supply pipes are still lead. Initially they requested me to change the lead to copper etc, but after investigation, the whole of the Hall is still on lead, and the wastes which are substantial are still in place. Now I've been told not to touch the lead !! From attached pic you can see the basin waste 11/4" as standard is then via some compression type fitting is attached to the lead waste. Does anybody know of a quick fit or multi adaptor to do the same connection ??? Thanks in advance ..
  2. ShaunCorbs
    Fernco coupling
Loading...
Similar Threads - Multifit connections Forum Date
Opinions needed on my options for dishwasher connections Plumbing Forum Saturday at 2:55 AM
Magnacleanse issue connections Plumbers Arms Feb 3, 2018
