waddmiester
- Messages
- 29
Gents,
I hope this is the correct forum.
The situation I have is that, as an afterthought, a customer would like to place a multi fuel stove in a corner of a room, within a single storey barn conversion.
One wall is an external wall of brick and block construction. It will be cement rendered. Therefore non combustible.
The other a stud wall infilled with insulation. As yet it is not boarded.
If this was boarded and plastered it would clearly be combustible and therefore require the full distances within the MI for the stove which is a Hunter Herald 6.
My initial thought was to put some block work in to the required height and width to bring the distances down.
However......
What, if any, would the difference be, if instead of normal boarding, 12 mm spacers were attached to the studding and then it was over boarded with non combustible board such as Hardiebacker ? The rest of the wall could then be double boarded to even it out.
I appreciate that this is a similar solution to shielding combustible materials from flues (i.e reducing the distance from 3 x D to 1.5 x D), but cant see any other reference to this in the building regulations.
In the case of the wall, could this then be considered non combustible?
Any thoughts / advice appreciated.
However......
