Discuss Mira mode mixer shower issue...maybe.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Moffski72
Moffski72
Anyone had one o these (mira mode thermo mixer) getting crossflow from cold into the hot? Tia
If the nrv is stuck open / broken yes very easily esp with higher pressure on the cold
no check valves on these...spoke to mira and they said they dont need em coz of the way the valve is designed...also its on a combi so equal pressures, give or take...
theres your problem if there not equal
best to check hot and cold pressures
Eh? Why would they not be equal pressures if it's a combi feeding the shower...?? They're both at whatever the mains pressure is. The hot might be slightly reduced through the plate I spose, but there's millions of mixers run off combis?
thats the only way they could cross
Reply to Mira mode mixer shower issue...maybe.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
