Discuss makita sds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I been using a similar 36v bosch cordless SDS and its great for getting clips on the wall etc but even on a full charge it wont go through a standard wall for a condense drain or similar, it either runs out of charge or overheats.
EDIT: oh hang on, just seen that its a 240v (link dont work, I read the text and saw the 24) - it will be fine, I use a similar hitachi up to 157 or whatever it is core drill
Which one do you have as there's two versions one is s compact version and the other is the full size version
If you have the full size version (36v) your talking out your bum as I have one and it will do 28mm easy no pilot
even used it to core a 4 inch hole through brick
well it wouldn't be unusual for me to talk out of my bum I suppose :D
all I do know is going through a brick/breeze wall wasn't possible, it ran out and I had to get the corded drill from the van.
no idea which model it is, it cost ÂŁ350
If this one then somethings wrong
hmm, i reckon its this one
..... cant post a URL so... from screwfix description: - Bosch GBH36V-LiCP 2.9kg 1.3Ah Li-Ion Cordless SDS Plus Drill 36V
That's the compact version jay think max it can drill is 16mm and 1.3 arnt going to last long
OOOh a Hilti style removable chuck, must.....resist....I....I....can live without it...got...too...many...
No you can't and Defo no you can always have more
Reply to makita sds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
