Discuss MagnaClean install - Boiler drain down? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
I want to install a MagnaClean on the boiler return and having looking at it closely I see a valve just above where it would best fit and a drain off at the bottom of the return pipe as it heads into the boiler. On he flow pipe there is another stop valve.
I would obviously switch everything off before starting but are there any potential dangers if I was to shut both valves and use the drain off to take out the water in the pipe? I didn't know if the boiler needed to be primed or anything again after or if I would just get away with opening the valves again, running the system and the bleeding the radiators.
Appreciate your advise.
Cheers
whats the pipe that looks like its going to the rtn ?. anyway you could turn BOTH those valves to top left of boiler unit off - if they work. Check mt cock to be sure. Then mess about fitting a magnaclean or even a better universal filter. it will need refilling after and maybe u will get an airlock but have a go and see. turn it off - let it cool and start soon b4 it gets colder good luck
needs a gsr engy to vent the boiler as there known for air problems
Reply to MagnaClean install - Boiler drain down? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
