  • Thread starter HHP Ed
  • Start date
  • Replies 39
  • Views 38K
Discuss Low Loss Headers. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
any reason you put the pump after the zone valves and no bypass for each circuit ?
Not finished yet Shaun re: bypass, The zone valves before the pumps is just the way I was shown but happy to be taught otherwise
Port valve are Better after pump else if pump after port could pull the port valve closed
Defo going into the same header the CT circuit going out to batteries and the VT obviously heating ,i installed all the circuit pipework along with couple other fitters and upon nosing in plant room thats what i saw .
it also helps the boiler from overheating, if you are running, lets say 100kw boiler and you are calling for hot water (from a cylinder stat) the boiler will fire up and normally would go to high rate 100kw , if the circuit it quite short, when the boiler shuts down the water is still heating up for a minute or so.The low loss header can take the extra heat preventing the boiler from getting to hot.
Reply to Low Loss Headers. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
