Discuss Loud banging from Worcester Bosch Greenstar 24i Junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can I measure the flow rate easily without one of those special cup meters?
Sorry I was wrong you can fill a bucket and time it never done it myself
Run the tap until it gets hot, then fill a bucket from your hot tap for 60 seconds, then decant the bucket into a measuring jug eg 1 litre at a time and this will provide your flow rate.
Someone checked the flow rate of the hot water for me today - it was around 5 litres/minute. As cdodds2004 mentioned in the previous post, it should be 9.8 litres/minute.
It was suggested that a clogged diverter valve could be the cause - is this likely?
Edit: Do you mean the small filter inside the turbine?
Reply to Loud banging from Worcester Bosch Greenstar 24i Junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
