Discuss Looking to replace expansion vessel on Worcester 28i Jr. combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SGman
my boiler's pressure keeps dropping within few hours. No dripping or leaks detected. A gas safe engineer suggested to change the expansion vessel. Would like to do it ASAP. Please give me a good quote. Thanks.
I'm at NW6 London.
Reply to Looking to replace expansion vessel on Worcester 28i Jr. combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Looking for someone that can replace the expansion vessel on an old heating system that is losing pressure every day and needs topping up at least three times a day. Trying to eliminate what the cause could be. Appreciate that it could be a leak somewhere, but looking to tackle one issue at a...
M
Hi, we have a back combi heater. Whenever the heating comes on it seems to lose pressure within a few hours and I have to refill each morning. The boiler seems to function well, and the pressure only drops with the heating and not the water being on. Ie it started last winter and was then...
Hi Is it possible for a DIYer to replace an expansion vessel and hose? It's an external grant vortex boiler and from what I've seen online it looks simple enough
3K
Hi, I have a Glow-Worm Easicom 28 boiler and i had to get a new 8 litre EV (expansion vessel) for it, which has arrived. i did check with the seller to ensure the new EV was correct for my boiler and he said it was. the query i have though is, on the original faulty EV, on the sticker, it says...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
