Discuss lock ..jointing compound paste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any one have experience with Lock-Joint Soft-Setting Oil Jointing Paste. I recently bought from hwos
It is blue and non setting.
Looking to use on oil line and flexi joints
Thanks for the replys. I have heldite but was looking for something a bit easier to work with.
Will give it a go and see how we go...
I use heldite I make a mess of myself but hardly ever had a leak on oil.
Loctite 577. Expensive but good. If Heldite didn't resemble tar then I would use it. My hands stay black for days!!
Anyone heard of oil resistant PTFE tape? If so where can I get some
Are you sure that it exists?
PTFE is resistant to oil anyhow!
It is a myth that oil can damage it. I think people assume PTFE is plastic tape, - it isn't.
Ignore the fact that PTFE tape goes slightly transparent when coated in kerosine. I have been using PTFE for last 40 plus years on oil and it will still be good as new on jobs I return to.
Do you ever use stag?
PTFE or sometimes bosswhite very rarely, apart from that never use much jointing compounds ,
Yes, I did use Stag sometimes, or similar Redex (or whatever it is called). But generally just needs right amount of PTFE tape on threads and sometimes smear of Heldite on oil fittings.
I prefer pastes for all compression or threaded seals and it definitely lubricates and adds extra seal to thread joints. PTFE tape will run into the joint much more extra and neater if you use some paste you will notice.
I use ptfe tape and red stag as i was told by oftec guy in northern ireland, on 10mm copper compression i also use brass pipe inserts to prevent pipe collapsing if over tightening. I have never had a leak with this method. Plumbers i work with at times say haldite is there favorite.
Reply to lock ..jointing compound paste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
Not exactly a plumbing problem but here goes. I have known for a couple of years there was a water leak somewhere between the water meter, on our property, and the property itself. The water company fitted a new (smart) meter about 4 weeks ago. Now they have contacted us saying we have a leak...
1K
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with elbows), the last cm before the open end is pretty much straight, but as a result of the bend it is not perfectly round. I mean it is pretty much...
Looking to see what iron pipe part can fit a 10mm ball joint? In this pic there is a part that connects the ball joint (or whatever they are called) to the 1/2 inch pipe. I am looking to connect to a 3/4 inch pipe. Are there any threads that do this? Thanks I have been told that in North...
Hello all, hope someone can help I'm after a joint which was missing from a purchase i bought years ago, just getting round to fitting it now, any idea where I can get one? Pipe inlet is 18mm diameter and thread is 3/4" BSP
