- Messages
- 194
I recently replaced a PRV on a cylinder that was letting by. I drained from the T&P valve and a little extra from the doc on the cold feed right before cylinder. I also repressurised the external exp vessel to just shy of 3bar as it was totally flat. I got a call yesterday saying that every ime the use the hot water they get a load noise. I popped in on the way home and it did it when I was downstairs but when he opened a hot tap once I was in the loft it died down very quickly. I turned down the lever valve before the combination valve and released a tiny bit of air from the doc but can see what it could be. I didn't check the vessel charge yesterday which I will do when I go back. It must be something I've done as it started soon after I did the T&P valve but I can't see what. Any ideas?
