Currently reading:
Limit stat heat tester????
Discuss Limit stat heat tester???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
magicno1
Hi guys
Looking for one of the testers for checking cut off temps of thermostats and limit stats. They are the electric ones that you stick the phial in a sleeve and you set the the temp and you can see the if the stat is shot or not.
any ideas of who makes them and where to get one???? I know they are quite pricey but you have to have one really not use a kettle!!!!
cheers
Reply to Limit stat heat tester???? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
