Discuss Limescale inside copper cold water feed pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W
wildwestwoman
I have a Triton T80xr electric shower (approx 5 years old). 4 months ago I successfully replaced the stabiliser valve and solenoid assembly after it stopped working BUT the heater has now stopped working again. It's obviously not worth replacing the same part again so I am looking at replacing the whole unit. My problem is the amount of limescale being washed out of the hose. I clear the limescale from the showerhead regularly so know we are in a hardwater area. If I remove the showerhead and turn the controls fully to cold the pressure obviously gets higher and I am concerned at the amount of limescale being flushed out. If I let it run for 10 minutes I get about half an egg cup-full of 1 - 3mm pieces of limescale and have been running the unit like this for several days now. The amount of limescale is the same every time! We had the whole house replumbed with new pipes about 6 years ago and nothing is being washed out of any of the taps in the house, just the showerhose. When I disconnected the shower to fit the solenoid I cleaned it and checked for limescale but didn't think it an excessive amount so I think the limescale is coming from the inlet coldwater pipe. Can anyone suggest: a) A suitable replacement electric shower b) How to prevent the same problem in a couple of years time c) Any way of clearing the limescale from the pipes without ripping out the tiled walls and floor!
I have lived in many hard water areas and scale will always be a problem.
The only really successful remedy I have fitted was a water softener.
The magnetic/induction/psychic methods have never impressed me enough to recommend them to a customer.
Having said that, I'm open to enlightenment.
Good effort on your DIY job but imho 5 years is average for an electric shower (some may disagree). Cheapest option would be a magnetic de scaler approx £25 easy to fit as it copression nut. Havent done an electric shower for ages so im sure someone will be along with a recommendation. Limescale only way I know would. limescale removal on a domestic level I wouldnt know and you need to be qualified at commercial level
Must admit I was a bit proud of myself! Looks like there's no real solution to my problem apart from replacing the unit every 4-5 years then? Ho Hum - it could be worse!
mountainman, I'm not unwilling to put in a water softener but will it deal with the limescale already in the pipes? And does anyone know why it's only in the showerfeed pipe?
It may well be that the lime scale is coming from the flexible hose between the shower unit and the head. These have a rubber lining, and when flexed will break off any lime scale which has formed on the inner side as flakes. Copper pipes don't flex, so the lime scale tend to stay fixed to them. When you replace the shower, try running the cold water through the new flexible hose with the head removed. If little of no lime scale flakes appear it suggests this is the problem. You could then consider de-scaling or renewing the flexible hose at regular intervals. However, this is a palliative measure, and not a cure.
Soft water will gradually dissolve limescale over a period of time and also has the advantage of requiring less detergent in washing machines etc.
Reply to Limescale inside copper cold water feed pipe. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
Hi, hope all is well! I’ve fitted a compression cap on two of my shower mixer copper pipes (15mm). One of them has scratches and burring and is very slightly out of shape. It leaked but I added some PFTE tape over the olive and it seems to of done the job. However… I’m tiling the wall and...
Hello All, New to the forum so apologies if do any faux pas. But I have an Aqalisa Electric Quartz Shower 9.5kw (8 years old) and currently it is only giving out cold water regardless of where the temperature control is placed, the only difference is the more you move to the dial to the cold...
1K
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A gardener/landscaping friend of mine is going to install an irrigation system in a customer's garden. He asked me to pop around and measure the pressures and flowrates...
Hi everyone, Recently all the water tanks in the attic were disconnected to connect to the mains water supply (mine was already on mains but the other 5 flats in the building needed to be connected to mains water) and the company were also going to fit PRV's and isolation valves to the pipework...
1K
