Discuss Leaking isolation screws please help in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. keo
    keo New Member
    Hi all, the head of the isolator screw has broken off and is leaking from the hole where it says hp and lp on the image. Any way this can be fixed please? Thanks
  2. king of pipes
    I would think the hexagonal brass nut unit can be removed and replaced as one piece contact the shower doctor would be my advice . cheers kop
  3. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Is it a Hudson reed shower?
  4. YorkshireDave
    YorkshireDave Plumber
    Most of time theres an o-ring behind it. Cleaning where it sits, lubricating & replacing should sort it.
Loading...
Similar Threads - Leaking isolation screws Forum Date
Water seperator filter that has been leaking from the seal oil line Oil and Solid Fuel Forum May 27, 2018
Leaking shower pod/wall hung shower unit Plumbing Forum May 22, 2018
