Discuss kent plumber needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tiling spread
any one in maidstone looking for work.
i need a rad removed and a bathroom moved from down stairs to a middle bedroom up stairs. (do i need planning for this)
maybe a new boiler too
im willing to help things along as im a trainee plumber. ( drill holes run pipes solder clean up make the tea )
we will be buying a new bathroom suite for the bath room (B&Q)
and ill buy all mats for the job too NOT GS PARTS if needed lol
all im looking for is a plumber to supply the labour ill buy all the mats
no tiling or anything like that just remove rad then re run pipes and waste for the new bath room up stairs (maybe fit new boiler)
ill need it doing asap
please email me [email protected]
or pm me ill send you my number
Thanks for placing your works requirement on the forums tiling spread
Anyone who can help,please contact as detailed in above post
Reply to kent plumber needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up & made safe for now, have had affected pipe cut & put end caps on. Work required Full bathroom remove old tiles walls and floor. Renew tiling. New...
60's ranch, with single bathroom. Tile over concrete slab. Toilet is about a foot from exterior brick wall. Vent pipe is in interior wall behind toilet. There's a concrete patio outside the bathroom, that extends about 10 feet from the wall. I'm considering adding an ADU in the back yard, and it...
I’m about to embark on a new listed building restoration project. There are seven bedrooms and three bathrooms, one of which in downstairs so not very convenient. I’ll be looking to sell on once completed and people basically expect a bathroom per bedroom these days 🙄 so need to get creative. As...
Hi sorry im a newbie, pls help if u can. I had a new bathroom installed about a yr ago and since then when i flush the toilet the room stinks of sewer gas. Not only does the b/room stink it also smells in the kitchen too, which is directly below the toilet/b-room. It doesnt do it everytime...
Hi all, can someone get to the bottom of this before I call a plumber, en suite shower started leaking from the mixer bar so took the shower off and capped it off for the time being, fast forward 3 months the same thing in the main bathroom, that one is leaking from the mixer bar, (no issues...
