Discuss Kane tightness testing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher buzzard
hey, new install. Vokera boiler, 1 rad and heat coil for a 6k Gallon koi carp pond. Had a seperate gas main ran to the log cabin plant room to feed the boiler with its own gas meter. He sorted everything and sourced boiler ect before I took on the job. Did a tightness test with my Kane. After 1 minute stabilisation the start was 20.10 mbar and finished at 20.06 mbar. Got a print out to staple to MI. I left but got a call this morn to say he could smell gas. When I walked in I couldn't smell gas and the door had been shut for afew hours. Did a test again, isolated boiler, sprayed all joints and I had a drop of 0.06 mbar. Would you say this is a leak or temperature/stabilisation affecting the reading? The reading was going up and down abit on my Kane as I watched.
That's what I was thinking. My Kane seemed very sensitive to the reading when I was testing. Do they charge for calling them out? I was wondering if the joint there side underground from yellow to iron was leaking.
No charge
The customer can smell gas but there is no leak when testing. Could be from anywhere.
anything under 0.25 you dont care about (as this is the readable movement)
so your well within wouldnt worrie at .06 i would start to look around 2 mbar on an existing install
did you use a u gauge to double check? my analyser has began to play up doing tightness tests. luckily its due a recal in January.
Do you test all the joints and connections that are only live when things are running?
Hey. Yeah I sprayed all joints. Even inside the boiler and used a U gauge. He sealed the duct where the iron enters the log cabin and spoke to him yesterday and he says he can longer smell anything. He’s gonna call the gas board out to investigate there joint underground.
Reply to Kane tightness testing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I think was very... ambiguous... advice. 12yo boiler with the following readings on the analyser printout: O2% = 4.1 CO ppm = 192 CO2% = 9.5 Ratio =...
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer & Vaillant engineer say one thing, whilst the SGN engineer says another. I do not know how to proceed and would value some informed advice. The rock...
1K
My water stinks. Smells musty. I installed a Whirlpool water softener mid February of this year ('23) and it's smelled ever since. So here's the story: we live on a farm in southeast PA. Our well is 60' deep with the water table around 10'. Two houses supplied from the same well. One day I...
New LPG installation with 2x 19kg cylinders outside, plus change-over regulator with isolator valve on output, then 10 metres of 15mm copper pipe (3 soldered joints only) running into house to the kitchen, to gas hob (with another isolator just prior to hob). System Failing tightness test...
2K
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
