Discuss Just been good to myself in the Plumbing Jobs | The Job-board area at PlumbersForums.net
we all have fella , mainly due to what we can afford at the time. but you buy a bit here a bit there soon builds up
Well, I'm only starting out on my own next month but I've just been good to myself too (eek).
I've got two bathrooms booked in which will involve 4 holes through walls (one a toilet waste) and hopefully more in the future, so at that price I thought it'll be a decent investment.
I've been in engineering for 25 years and have learned that it's worth having decent tools. I've never used diamond cores - my last toilet waste was a nightmare through super hard brick chain drilling with an SDS - looking forward to seeing what the difference is like :)
nice one matt, will make jobs a lot easier
Cheers dancin'
Looking forward to coring my first soil and seeing how it performs :)
And thanks for the heads up CES - a good price - way cheaper than anywhere else I've seen.
well drilled the new flue today , new bit and 5kva trasnformer - it flew threw like theres no tomorrow
great buy ces , cheers
Damn this thread, have just odered a DDM2 and set of cores also, looking forward to trying them out.
you wont be disappointed only down side to the set i got was , theres no extension bar included but i do have one so not a biggy to me, you got them from same place ?
i dont just blankets down then a nip round with the dewalt cordless
Yup ordered from the same place, seem about the best value i've seen, i may have to organise some extensions as i've only got the ones from my sds set
might have one in the shed fella ill look tomorrow its getting a clean out
i spoke to lad in shop on saturday ,they were on about putting price up lol
no it was tbh , was trying to tempt me into getting one, i came close
I've used mine a few times since I got it, it amazes me just how much of a difference a decent drill and cores make.
The only thing I need is to get a couple more extension pieces, makes light work of tenement walls (4ft thick).
It was Tamz we should be thanking for pointing me in the right direction with this!
im like the kid on christmas morning , grining ear to ear , i even text the mrs and bragged never had a good a set up as this
if bod carnt find his have got sum spare ones, they are 1/2" male/female bout 300mm and hollow.
pm me , will send ya one for p+p
PTS sell extension bars for about a tenner for a 250mm or 300mm whatever it is. You can keep joining them together.
Deepest hole i've cored is about 6ft (that doesn't sound right :smile:) from a pub toilet (worse :blush5: ) through at an angle to above a suspended ceiling. Just kept adding extensions. Lots of extensions puts a lot of strain on the gun tho.
Gave it a go today, am very impressed, put 162mm core through in no time. Only slight criticism is its no the most ergonomic design and would probably be a little uncomfortable to use for a prolonged period, but all in all well recommended. :)
Reply to Just been good to myself in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Advice from experienced plumbers will be appreciated. I inherited the old stopcock without a disk (2 pictures below). Attempts to find a lever or disc with 8mm rectangular hole were unsuccessful and use of a locking plier was not convenient in emergency, so another stopcock was fitted after it...
Deleted member 120897
Hello, I have a tank Bradford White 50 gallon gas hot water heater for a 1700 sq ft home with 2 1/2 baths, HOWEVER, I am only one person living there. It was installed in March of 2015 so it is 8 years old. I believe life expectancy for a typical hot water heater is around 10 - 12 years so I...
When we moved into our house in 2016, the electric water heater popped loudly when heating. After awhile, I researched and realized that it was likely due to limescale and/or other sediment buildup. I flushed it multiple times, but never got it to stop popping, so I eventually decided to replace...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Hi All, My first visit here in quite a while and it's in part to share the news that I have finally gone over to the dark side! Although my 30 year old Baxi back boiler was still going strong, I've finally succumbed to pressure from Mrs RWD and had a Combi installed. The Heating Engineer that...
