Discuss is this how my oil boiler works.....Grant Euroflame 90/120 Kitchen/utility boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
pspec
Hi
I have a Grant Euroflame 90/120 Kitchen/utility boiler and I think I’ve worked out how it works.
The boiler is outside in a shed.
There’s a standard 3 wire mains power cord going into it (no other wires).
4 pipes coming out, 2 heats the centre heating, 2 heats the hot water.
There’s 1 pump in the shed for the centre heating 1 pump in the house for the hot water.
So as there’s only the power cable going into the oil boiler i think the boiler must only monitor the temperature of the water that’s actually in the boiler. So it must maintain the temp of say 1 litre of water so if the pump is turned on it heats all the water in the system.
(At first I thought a thermostat inside the house would control the oil boiler but as no wires except the power cable goes into the boiler that can’t be the case…)
So I’m now concluding that the room thermostat controls the centralheating pump and not the oil boiler and again the thermostat on the combo electric hot water cylinder must control the pump and not the oil boiler.
Also if all of that’s correct then doesn’t that mean if the oil boiler is constantly heating say that 1 litre of water for when the pump is turned on isn’t that a waste.
I would of hoped the thermostat would control the oil boiler directly and so it would only heat the required water..
So how much of that is correct….
It should all be interlinked to give control over the boiler.
If the boiler fires up on its own with no demand it's not wired correctly.
That's how some older systems work. It's as you say...the boiler keeps itself hot then water is drawn off as needed.
They were designed that way for simplicity when fuel was very cheap.
You can improve the situation by modifying the controls so that you are only feeding power to the boiler when there is demand. However, this is not a DIY modification.
Something you can do yourself is check that the insulation on the boiler and especially the pipework is in good order.
As above. Old systems relied on boiler stat for control. Swap to S plan, get 2 or 3 estimates.
Reply to is this how my oil boiler works.....Grant Euroflame 90/120 Kitchen/utility boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler, and where the pipes come in is in a room at the front of the house. I am about to box them in but I really wanted to understand what the various pipes...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi all, I wanted to ask a general question about an underfloor heating system our plumber is proposing and if this solution will be sufficient to heat the rooms. We have only a woodburning stove (15kW nominal output) that heats our open plan lounge/kitchen/diner directly (6.5kW from the...
