Billy Bob Bob
changed the AAV today,finally got back and sorted it,could not fit the one i wanted as i could not shift the bottom half,luckily a baxi combi aav is a direct fit,however its clearly been leaking sometime and drops pressure over about 3 weeks,EV is fine,tested,doing its job,its non condensing,no leaks in the system visible ,old aav was shot,but with this corrosion could it be leaking through the water jacket? steel looks quite thick,no obvious signs of leaking around the corrosion,customers had it serviced with a oftec guy but he was not interested in sorting out the leak,so i did,trying to fix the issue
