  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
  2. WARNING! We do NOT provide advice related to Gas or other fuels to people who are not currently an official registered Heating Engineer. Do NOT ask for advice related to boiler repairs or installs. You need to find a heating engineer instead.
    Either seeking or providing advice on UKPlumbersForums.co.uk may result in your account being suspended or removed. These rules are in place to prevent deaths, which can easily occur from messing with heating systems when you're not qualified to do so.
Discuss is it the boiler or something else? in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
  1. Marina
    Marina Guest
    I have just moved, the house has a 10 month old Baxi Main 24 HE combi boiler and 9 radiators.
    Over the past 10 days, problems started with boiler and radiators:
    The boiler loses pressure - all the way down to zero, gradually - whether the heating is on or not. I have to top it up every time I need hot water, basically at least once a day. Yesterday I had to do it 4 times. Now it doesn’t even fill up properly. When the heating is on, it will lock out after a while, pressure right down and flame failure.
    All of this has been getting slowly worse over the past 5 days or so.
    I tried to bleed the radiators:
    The downstairs ones (5) are ok, except for 1 that cannot be bled as it’s too stiff
    The 4 upstairs ones: I can open valves, but nothing comes out, no air, no water. They do work though, ie they get hot when boiler works.
    As the boiler is still under guarantee, I called a Heateam engineer, who said the boiler’s absolutely fine and the problem is elsewhere. He checked for leaks inside the boiler and the wall outside, no leaks.
    Any ideas?
    Many thanks
    Marina
  2. Bernie2
    Bernie2 Guest
    I don't know whether its been done or not, I imagine it has, but the usual thing is to check for any air in the system. Check PRV overflow. Check expansion vessel. And if no sign of a leak anywhere on the system. You then have to ask yourself where else the water could be going and without knowing the system its a bit hard to do that.
    After all a sealed system is only like a balloon. It has to have a hole in it for the water to leak out, if its loosing pressure at a faster rate than is normal for the air in oxygenated water to be displaced when the water is heated causing a pressure drop.
  3. moony
    moony Guest
    leak in system - if prv has been checked and expansion vessel hasnt lost its charge then check rad tails for leaks - pipework - any damp etc etc. if there is as much water lost as your saying (filling 4 times a day) then there is a pretty good leak somewhere.
  4. REDSAW
    REDSAW Guest
    check the prv again, there prone on theese boilers.
    after 5 days i would have expected a noticable leak somewhere unless the pipes run under the downstairs floorboards.
  5. Toddyplumb
    Toddyplumb GSR
    If its only 10 months the installer should come back. There details will be on the benchmark !
  6. easyt
    easyt Guest
    If you are on a water meter then if there is a leak the little star shaped piece in the middle of the gauge will be moving. I thought I had an external leak last month and contacted the water company. They put a temporary meter on to test. (No leak - a natural spring). But it showed even a slow dripping tap. (I set a tap dripping very slowly whilst the guy was here as I wanted to see how sensitive the meter was).
    If you are convinced there is no leak - but common sense says there must be you can always get a temporary meter fitted to confirm your worst fears. Are there pipes under floor boards?
  7. oldplumber
    oldplumber Guest
    You seem to have lost the thread here which will puzzle the initial poster as we are dealing with a sealed system thats losing pressure not a cw main thats leaking!
  8. GPSNewcastle
    GPSNewcastle Guest
    Leak in the pipework somewhere, if its not losing pressure through the PRV then this has to be the problem..(there is not need for any meters/meter readings etc as this is a sealed system, you fill it up, it loses water through the leak then you fill it up again). It has to be somewhere under the floor if it is not noticeable as for the boiler to drop from 1.5bar to zero four times in a 24hr period the leak must be sizeable
  9. easyt
    easyt Guest
    Yup. I was forgetting how they worked. dohh
Loading...
Similar Threads - boiler something else Forum Date
Combi or system boiler Central Heating Forum Yesterday at 8:51 PM
Air in boiler Whooshing Central Heating Forum Thursday at 9:56 PM
Ariston boilers???????? Plumbing Forum Wednesday at 7:42 PM
Anton Evo 3 Boiler Efficiency Central Heating Forum Wednesday at 7:21 PM
Booster pump installed successfully, but now boiler goes to overheat! Plumbing Forum Wednesday at 2:03 AM
Combi boiler replacement? Central Heating Forum Monday at 12:58 AM
Bermuda Back Boiler spilling Central Heating Forum Jul 14, 2017
